- 13 Aug 2004
- England
Hi guys,
I have some joist ends that are in need of trimming and replacing on a suspended timber floor that rest ontop of a timber wall plate (also to be replaced). How would you go about securing on new timber to the ends?
I have seen a couple of methods, either by using L shaped "joist end repair plates" or by overlapping the timber by 600mm and using 5 x m12 bolts through at 100mm intervals. I was thinking the second method would be more secure and that I could also use some 5mm galvanized steel bar to make a pair of U brackets on the ends to increase strength.
Thanks for any advice!
