You actually need a torx 7. I did mine a few days ago.
Its so nice having 320Gb available![]()
How did you guys know which drives would be compatible?
Ta.I think most 2.5" sata drive are compatible. I've got the this one if thats any help.
Ta.
What method of transfer did you use?
Is that sata>usb just the same as an 'icy' enclosure?
Here's a good question too. Any drive, once up and running, always actually gives you less space than it is. E.g. a 120gb drive actually gives you 90gb to use.
Is there a forumla to work this out for all drives. Is it always 1/4 of the drive that's lost?
For simplicity and consistency, hard drive manufacturers define a megabyte as 1,000,000 bytes and a gigabyte as 1,000,000,000 bytes. This is a decimal (base 10) measurement and is the industry standard. However, certain system BIOSs, FDISK and Windows define a megabyte as 1,048,576 bytes and a gigabyte as 1,073,741,824 bytes. Mac systems also use these values. These are binary (base 2) measurements.
See post 15Erm no it doesn't.
Mine is 111.5gb formatted, something seriously wrong with yours!
OEM Recovery Partition?
