Ok so my master socket is a bit old, and to be honest after I looked behind it there's a right pigs ear of extensions just twisted together with the main incoming line.
I'm with Sky for everything and I asked them if it was ok to upgrade my master socket to a new one with a built in filter they said it was ok, although i've read it belongs to BT not my "provider" but meh, I decided to just do it anyway.
After sorting all the wires behind the socket out and connecting them properly i've just put it all back together. It works! thank god for that!
Here's a little "before and after" info.
Downstreams:
Line Attenuation: Before - 38db After - 34.5db
Noise Margin : Before - 7.6db After - 7.2db
Not bad drop on the attenuation there, and I don't understand whats good for noise margin perhaps someone can tell me if lower or higher is better.
Won't bother posting upstream as it's down that really matters!
Sync speed before was 8909kbps (down from my 10mb a few months ago) so i'm hoping I can get back into double figures now. There's been a long running fault at my exchange sky say, so will see how it goes! Just away to call Sky to get them to re-run my dlm.
Downstreams:
Woot! Sky rock at customer service.
