Greetings chaps,
I'm looking to do an almost complete overhaul of my old PC. My Budget is around €500 (aprox. £400) I bought my Rig quite some time ago. It's an Alienware pre-built system, and it ran well for a number of years. I replaced a few parts peace-meal over the years such as the Graphics card and the RAM, but now it's really beginning to pack up. I've decided to replace the Mobo, CPU, RAM and the two case fans. I just thought I might ask you good folks here on the forum for a bit of advice before I take the plunge.
My current Mobo is the INTEL D975XBX, and I'm currently using a 485w 12v Enermax powersupply, Link Here).
I'm also using a 500g Hitachi 3Gb/s HDD (I'll probably upgrade from this , when funds and time allow), and a Sapphire Radeon HD 4670 1GB GPU.
I'm intending to use this Rig for some smooth, fairly high FPS gaming, but not overclocking.
I know I could do better with the Graphics card, but my budget is limited, and I will probably pick up a card in a sale some time in the future, and use it with Crossfire (any suggestions for a likely candidate would be very welcome).
The two casefans I'm picking up are 120mm (http://www.overclockers.co.uk/showproduct.php?prodid=FG-000-XI) and 80mm (http://www.overclockers.co.uk/showproduct.php?prodid=FG-002-XI).
I'll be replacing my CPU, RAM, and MOBO with the following:
CPU: Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W)
MOBO: Gigabyte Z77X-UD5H Intel Z77 (Socket 1155) DDR3
RAM: Corsair Vengeance Blue Low Profile 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz
Case fans: 120mm, and 80mm
My main worry, not being terribly tech educated (not tech-illiterate though mind you), is compatibility issues. I'm not entirey sure if I'll need a new power supply to run this Mobo. Also, will I need to perhaps downgrade the Mobo, and invest in a better case if those two fans alone might not provide the necessary airflow for that kind of processor. Otherwise, I would just like to hear any opinions and suggestions anyone might have.
Cheers.
Cheers.
