Replacing my laser printer which should i get ?
29 Dec 2012
Hi guys im looking advice.
My printer has stopped working and needs a few part to get working , I did try to repair the old ones with some suggestion off here but no luck.
So my options
Option 1. Get another used HP 4100 used but working. £40
im not sure how much toner it has left but i can use my own.
Option 2 get a new hp M130 Multi-Function laser printer which is a little smaller £50 after cashback
this is for home use.
The majority of budget laser printers sold in this category are in effect disposable. If it breaks, you often find it cheaper or more cost effective to simply replace the whole printer with a new one, comes with warranty and a starter toner, but check the toner costs/3rd party compatibility as that tends to be the sting in the tail.
