Hi all,
I posted here a few months back regarding HDD issues which I solved by replacing the HDD. Now I've run into new problems I'm certain are motherboard related, but I have a bit of a budget to play with this time so I've decided to replace pretty much all the major components.
Current spec:
Case - Antec 300
Mobo - Gigabyte H55M-UDHZ
CPU - intel i3 550 3.20 Ghz
Cooling - Corsair Hydro
GPU - Nvidia GTX460
PSU - OCZ Stealth XStream II 600w
HDD - 1TB Seagate Barracuda ST3100534AS
Soundcard - Asus Xonar DG Audio
Ram - 4GB Corsair
OS - Windows 7 64-Bit
I want to keep the case w/fans, and the (new) HDD and replace everything else, switching my current copy of Windows to a SSD. I'd also prefer to stick with intel and Nvidia, as I'm familiar with both and neither have let me down. The soundcard isn't essential, but I'd like advice on a new PSU, Motherboard, GPU, CPU, RAM, a SSD, and, if necessary, alternative cooling for the CPU.
I should add that this will be primarily for gaming; I'm looking for decent FPS and the ability to play current games at med-high settings. My budget is £500 - £700.
Current spec:
Case - Antec 300
GPU - Nvidia GTX460
Ram - 4GB Corsair
