- 11 Mar 2008
I've been running powerline from downstairs near my Fibre (FTTC) router (with a small collection of LAN devices) up to my computer room upstairs where I have 5 or 6 devices connected by Ethernet.
Problem being that the Powerline adapters are interfering with the Fibre connection (causing a drop in connection speed overtime, currently down to 29Mbps from the 'standard' 40mbps)
In short, I want to get rid of the powerline adapters to prevent the interference - however running an ethernet cable isn't an option unfortunately, so the only other thing I can think of is to setup a Mesh Wifi system, however I'm not completely sure whether any Mesh devices actually support Lan bridging (any mention of bridging that I find relate to setting a router to bridge the WAN connection)
Is LAN bridging just a standard option for Mesh, so doesn't need to be mentioned anymore? Devices like the Linksys Velop and the Netgear Orbi have LAN ethernet ports on each satellite device, so it looks like LAN bridging would be supportted but I just can't find anything to confirm this and the reviews I've read don't seem to test this (it's all about Wifi signal)
From what I've read, it seems like the Mesh (assuming they work the way I think they do) should provide a connection that is as fast (if not faster) than the actual sync rate of the powerline between upstairs and downstairs.
Info relating to the Fibre interference, my connection had been 40Mbps for a while, however I noticed it drop off over time, eventually getting to 20Mbps. An engineer came out, rewired everything (at the house and at the cabinet) but eventually found that when the powerline was disconnected the Fibre sync was pretty much perfect, however when powerline was active it was generating thousands of errors on the fibre line. I've managed to run a cable round the lounge so that the powerline is connected around 2.5m away from the phone line now, the errors are reduced but not gone, so my Fibre is still dropping in speed over time
Any feedback or suggestions are welcome
Thanks
Thanks
