- 6 Dec 2009
Hi,
I'm new to the forum. I have the issue with both my sixaxis pads that the return springs in the multicontroller pot of my left analogue stick has worn out.. the pads are now next to useless for accurate gaming....
From lookin inside the pad, soldering in a new pot would be pretty easy, and looking at the company ALPS who make very very similar controllers the part would cost peanuts... The problem is WHERE CAN I BUY SOME!!!!! the exact part is not identifiable on the ALPS website.. only a unit which is identical but 2mm wider (so contact pins would not line up-this is incidently the exact part used in a Dual Shock 2 pad). ALSO Alps will not converse with or sell direct to customers and sony nor Alps will give the part specs.. unsurprisingly...
Before people say so, I will just buy a new pad.. BUT, if anyone knows where to get a brandspanking new part, it would be a very cheap alternative to a £35 new DS3 pad...... I will also do a HOW 2.. and post on here if I can get the part, so eveyone else can enjoy a basically new bad for a few pounds
I saw user 'L33' had made a custom PS360 pad which looks like awesome work and has also dissected the PS3 analogue stick set up.. I thought he may know of a source of these parts, but PM is disabled on this forum...
Any help from anyone would be great
thanks
Lock
Lock
