Replacing stock fans
21 May 2018
South Wales
Just ordered the Phanteks Evolv Flow Edition case and I'm in the market to replace the 3 140mm PH-F140SP fans that come preinstalled, any recommendations?
I would wait until you get the system built and then decide if you need different fans.
I have 3 of these fans in my Pro M and i find them very good for air flow and noise.
i have 4 of these in my phanteks pro m and they're pretty decent.
My basket at Overclockers UK:
Total: £18.65 (includes shipping: £4.66)
I have been looking at the 1500RPM variant of this fan and torn between the 2 and the Corsair ML140's?
The Noctua's work out cheaper in price as I only require 3 and not 4, however I want the best performance for case airflow at a reasonable price.
I've seen the Phanteks SPs recommended as case fans a lot. I'd really recommend trying them first.
I probably will as they seem to push as much airflow as the NF-P14s fans if the spec sheet is accurate, although these are 3-pin not 4-pin PWM.
the 1500 ones will be a bit noisier. i just have the 1200's purring along at 800 and their quiet.
be quiet silent wings 3 or noiseblocker nb-eloop are very very quiet.
I've just ordered 3 of the 140mm be quiet! Silent Wings 3 high speed fans, I've used be quiet! in the past and where exceptionally good quality.
My daughters build gets toasty after long periods of gaming, so I've gifted the preinstalled fans to her.
Good choice. I hope you can tame those high speed fans down with bios (or other) fan control because they can get noisy at high speed.
That's where a custom fan curve comes in... however my case has a fan controller but it only supports 3-pin and not the 4-pin these fans require?
