Thought I would go out on a limb here and see if you guys can help me at all.
Trying to replace my suspension coil for MOT, on a 99 clio.
So, on the top is an allen key and a bolt. Been trying all weekend and am completely stuck, unable to get this bolt to shift (the whole thing moves, just not the bolt) Have managed to twist the allen key quite well just from brute force.
So, tonight I'll try clamping the suspension with mole grips to try and lock it so it doesn't move (as using wd40 has allowed some movement), but anyone got any tips on how to free up the bolt a little?
Have drenched it in wd40 which worked when replacing the tie rod end, just wondering if there is anything else I can do?!
