Replacing The LED Fans?
10 Mar 2010
Right so i have my system working fine temps didnt get too high max was 47 during about 6+ hours of data transfers using usb drives and - is 47 good? the average was like 30ish, but it mostly stayed around 27-35 (26 being the lowest)
anyway i was thinking about replacing the 2 LED fans - i dont think it should be too hard to do but i was wondering will they have the same connections as the current ones i have - i got a fan controller but the connections on the end of that wont allow me to connect the 2 LED fans to it i want to go with 3 x white - adding a 3rd on the case, anyone have the Coolermaster Scout case and changed the fans? i think the biggest problem would be the intake fan, would i just go and find the connections for it and connect the new fans to them connections?
