Hi folks, been taking an enforced hiatus due to cash flow .. but back
MY rig is currently back on Air GPU and WC CPU on one Rad
but things are going horribly wrong ..
not wrong in a "OMG WATER ! WATER EVERWHERE!"
more of a .. turn on rig and the pump takes 30 seconds to finally turn over.
I've stripped and cleaned the rig but both pumps still fail to perform
so I'm guessing that they are goosed .. or just can't handle it.
so
I'm gonna replace the lot
the pumps I want are D5 Varios ( or so I'm told they are the best )
get Rid of the dual DDCs and the Bay res
I'm hoping to keep the same size tubing and the fittings ( it's 3/8 ID 1/2 OD )
put in one or two cylinder res and the D5's
would one pump work for the amount of restriction I've got ?
for those too lazy to look at my rig pictures
three HD5870s covered with full block EK's
one AMD Thuban CPU
and a lot of raddage
or will I need moar power ? the dual DDCs is series worked well for 8 months before they died
let me know your thoughts on items to buy and things you would do different
I'll be buying in about 3 weeks time and then fitting straight away
Cheers for input
OCD
so
one AMD Thuban CPU
Cheers for input
OCD
