I've started having issues with my somewhat aging Samsung UE48JU7000 developing several large purple spots in various places across the panel. My googling tells me this is a pretty common fault. Handily I bought the TV from Richer Sounds so despite it being 5.5 years old its still just inside it's 6 year warranty. I've jsut had the confirmation that they've matched it to the Sony KD49XH9505BU and I'll be receiving a voucher for £899 that I can use to purchase this. To say I'm elated is somewhat of an understatement! Assuming it all goes to plan it's going to be about the best warranty exchange I'll have had.
However, where I'm seeking advice is if this is the right TV to go for? With it being a voucher I can use it towards a TV that's more expensive should I wish and I think I've narrowed it down to two.
The first is simply sticking with the Sony KD49XH9505BU as a direct swap and I'll be able to do this at essentially zero cost.
The other option is to go for the LG OLED48CX5LC which will cost me £400 after using the voucher.
Based on reviews I think either are going to be a huge upgrade for me, but I wonder what others in my position would do. Whilst I've always been impressed by OLED on the brief demos I've seen them is it going to be worth the £400 upgrade cost over the sony? It's worth mentioning I don't currently have space to fit anything larger than a 50" so I can't step up to a larger size.
I primarially use the TV for watching films and tend to value colour accuracy / realisim over hugely vibrant overblown images. Whilst the TV is occasionalyl watched during the day for anything serious it would normally be used in a relatively dimly lit room or with curtains closed.
I do use the TV for gaming as well and currently have an xbox one x connected to it. This will probably be swapped for a series X in the future.
Thanks for your help
