Replacment Case
14 Jul 2004
I currently have a Corsair Carbide Series SPEC-06 RGB Tempered Glass Mid-Tower Gaming Case in black. The power button has now stopped working and can't seem to find a replacement.
Could anyone suggest ot recommend a good replacement case for this.
I can try but when you look up that part on there site it says its unavailable and sounds like they ain't going to get any in.
I've had similar with other cases from different manufacturers in the past and have had luck asking for a part that isn't listed as in stock (or even listed on at all) they may have some lying around.
It doesn't hurt to ask!
You can try to use a anti-vandal SWITCH / PUSH BUTTON 19MM, BLACKLINE DOT - RGB or similar.
