- 25 Nov 2009
We're going to have a log burner fitted, the returns have always been boarded over, back wall bare brick. I have exposed it all with a view to making it presentable enough to be left bare. The plan is to smash the hearth up and replace with a larger slate hearth to allow the 225mm in front of the stove.
I've never repointed before, I also need to replace a couple of blown bricks.
All doable? Reasonably handy, I have a grinder so thinking of getting a mortar disc, also a mortar rake for the drill looks handy. Cut around the damaged bricks, knock them out and replace with a spare, mortar gun all the gaps.
Bed the new hearth on mortar and square up.
I have spoken with a local fitter who will be lining the flue and fitting the stove as per regs.
Is there some kind of non combustible trim that will tidy up the plasterboard/wallpapered edge? Or any other wisdom you guys can impart?
Many thanks
Many thanks
