reprogram XMP?
Permabanned
11 Jan 2019
bedlam
is it possible to reprogram the XMP on ram?
i have some 2400mhz ram that runs at 3200mhz but every time i chance somthing in bios like CPU overclocking and the system isent stable i have to reset up the ram times.
The paid version of Thaiphoon burner can do that, you need the pro version for XMP programming, ive done it myself to fix a G.Skill Trident Z Kit of ram that the LED software used to corrupt the SPD on the sticks, but also gave you the ability to reprogram the XMP, there is a thread on another forum on how to do it, i'll see if I can find it, you have to be very careful as you have to make sure you are flashing the correct address range.
Post 36 onwards: https://www.overclock.net/forum/180...ify-flash-spd-xmp-profiles-ddr4-eeprom-4.html
Just save a BIOS profile that you can load each time it resets for failed CPU OC?
Thank you.
