- 26 Dec 2013
- 404 Not Found
I'm looking to change around the layout in my Leopard Geckos setup, and go from using a ceramic heat lamp to a heat mat instead to save some money on the electric bills.
I have a 36" long, 16" deep by 18" tall wooden vivarium with a glass front.
My idea was to buy a 17x11" (40W) heat mat and attach to the inside floor, put a thin 5mm layer of sand on top, and then use some ceramic tiles for a DIY store to go over the top. The heat mat will be controlled by a thermostat with the probe on the tiles.
Is this a safe way of doing things, or is it going to melt?
