Repurposing a Deskmeet B660
18 Dec 2007
London
Hi all,
My SIL has asked me for pc advide for her kid, who's turning 13 just before Christmas.
A couple a months ago i've put my Deskmeet B660 (i5-12500) away, have built a bigger media sever instead.
Would I be able to rehouse the inners in a rgb-type case?
He wants to play Minecraft/roblox and he's starting to make short video's for youtube.
Would something like a RX6600/7600 be ok for this? Looking at his age he'll want to get into other games as well.
Why not add a GPU like the rx 6600/ 7600 to your deskmeet will be plenty for 1080p.
DeskMeet can fit a dual slot graphics card (up to 20cm or 7.87 inches)
The Asrock motherboard is itx so a itx or matx case with RGB is an option.
The power connectors look like they're standard ATX, but the screw positions are a little funky, the two on the right hand side don't look like they're in normal positions.
In the manual you can download on their website, it describes the board as "ITX" and says the 24 and 8 pin connectors are ATX.
