request ; case pics
13 Jan 2006
Wigan
can any Lian-Li PC V2000B PLUS owners post a pic of there case wireing job, water cooled or not, wanting to get an idea of how it all fits.
i did a search and ended up trauling thru the watercooled case pics :P
thx
http://files.tagworld.com/ca63f07050bd48a84464b13cace0b23c6956.jpeg
The HDD's have been reversed so that cables are largely hidden behind cage .
A small cut was made in the divider panel to allow for cabling/tubing to be routed.
The front USB/Firewire leads have been routed behind the mobo plate, and come out at top of picture. Just take off back side panel and route the cables using cable tidy's to keep them together.
Hope this helps you.
you need to resize that pic to 800x600 or link to the pic as a don will delete it.. nice setup
thx for the pic, i wanted to see how much space u get to play with and it looks like loads, that a 120.2 rad?
do u think u could fit a 120.3 or is the space why u went for a 210.2? i wouldnt want to have to hack holes in the case to make one fit
also i notice u dont use the 80mm fans, this for noise or is there no real point in using them?
Yes it is a PA120.2 rad.
You can fit a PA120.3 in the bottom section, but you will need to remove the HDD rack to fit it in. You could house any HDD's in the 5.25" bays instead.
Both 120mm fans at front + back are in use - the front one has been housed in the space between the case front and the internal plate (see thumbscrews on fan retention plate) as this gives more room rather than squeezing in between the normal fixture between the internal plate and HDD rack.
If you install the rad in the bottom, you will need to cut 2 x 120mm circular holes for any fans. I have 2 x Panaflo 38mm fans that are underneath the rad and then have a Thermochill grill on the case floor.
