- 31 Mar 2006
afternoon all,
Would really appreciate comments on the spec below. will mostly be using her for fairly intense web dev related multitasking during the day & a bit of gaming of an evening etc - nothing too demanding on the gaming front though as I royally suck at FPS's. will probably have a crack at overclocking but am not a proper tweaker...
Probably worth mentioning that this is also something of an interim spec as I need a new system now (my venerable 1.8GHz P4 is gradually grinding to a halt after 4 years of good service) but my budget is limited to 800 quid or so.
Hence I plan to add more storage, ram and poss another GFX card in a few months.
CPU - AMD Athlon 64 X2 Dual Core 3800+ (Socket 939) - Retail - £179.95
RAM - Corsair 2GB DDR XMS3200C2PT TwinX (2x1GB) - £109.95
MOBO - Asus A8N-SLi Premium nForce4 SLi (Socket 939) PCI-Express - £99.95
GFX - Gainward BLISS GeForce 6800 GS "Goes Like Hell" 512MB GDDR3 TV-Out/Dual DVI - £139.95
HD - Hitachi Deskstar T7K250 NCQ 250GB SATA-II 8MB Cache - OEM - £56.50
PSU - Enermax Liberty 500W ELT500AWT ATX2.2 Modular SLI Compliant PSU - £61.95
subtotal = £648.25
+ evil mr VAT man's slice = £113.45
total = £761.70
all this will be sitting in a custom coolermaster that I already have, and will be using opticals from my old system for now to maintain cheapness in the short term.
should I maybe be looking at a tagan PSU instead of the enermax? I know they're popular here but have heard mix things elsewhere...
would also be grateful for any suggestions as to whether I should bother improving on stock cooling for the CPU, and if so what you'd suggest.
many thanks in advance
meta
subtotal = £648.25
total = £761.70
meta
