Request help for my first water cooling
Do you have a budget?
Do you plan on water cooling the graphics cards?
What case are you using?
please recommend a watercooling kit to me. this is my first time to bulit system. hence i dun know any about watercooling..please give me more specific idea. such as brand and modle which is easy for me to find on the shop.
You need to install waterblocks on the 580s as long as they are reference design.
I looked at your case on antec.com, but going to bed now so haven't looked up reviews.
Basically you need to work out how much room you have for radiators, so far I'm guessing you have room for a 120.2 in the back. you may have room for 140.2 in the roof and 120.3 in the front but I can't say at this time.
Have a read through the stickies and guides to get an idea about what you need to do. All the 'kits' are CPU only so you need to make your own custom setup. Takes planning.
Also, don't chain posts together, use the edit button, it helps for reading the thread.
get doing some research read the guides watch some vids,a quick look on OCUK and i get this
http://www.overclockers.co.uk/showproduct.php?prodid=WC-068-XS&groupid=962&catid=1520&subcat= x 2
http://www.overclockers.co.uk/showproduct.php?prodid=WC-079-XS&groupid=962&catid=1532&subcat= or http://www.overclockers.co.uk/showproduct.php?prodid=WC-082-XS&groupid=962&catid=1532&subcat=
and then a few extra fittings and some fluid
im no expert new to water myself but that gives you alittle idea what 2 look for
like jeff says above research, keep doing it take your time dont rush and u read posts and such u'll get your own idea in your head as to items u need, im new to water cooling as well and i actually spends months on and off looking thry forums etc and my 1st idea was to get 1 of the EK kits before changing my mind and building up a loop buying stuff that i thought was good and recommended off the forums etc.
my setup is very quiet just make sure you have a fan controller,i only turn my fans up on pc if im stressing it all other times its on lowest speed and idles 20+ and maxes out 45+
