[Request]I9-9900K
18 Oct 2022
Italy
Hi,
I'm a newby and I would like to OC my Asus PA90 with I9-9900K to 5/5,2 MHz.
My OC Menu on the bios is different from the other Asus flatform.
Attached you will find the pictures of the OC menu and Thermal menu, since I think I need to change also the liquid features to prevent throttling.
Can you help me configuring the OC?
Thanks!
https://photos.app.goo.gl/JauGjgadYcxLRrYPA
With the single 120mm aio cooler i wouldn't overclock the cpu as that cpu is pushing limits with a 120mm aio already. Plus you only have a slim 120mm fan. What temps are you currently getting?
