Require help making monitor choice...
3 Dec 2003
Kent, UK
Hi.
I am looking for a good LED 22 or 24 inch monitor for under £150 (if possible). It will mostly be used for photography work, a bit of movie production and then the odd game or two (Dirt 2, CoD, Just Cause 2).
Ideally it must have D-Sub, DVI and HDMI inputs and even better if it doesn't need a seperate power block.
Is LED a good option or should I stick to LCD?
I am blinded by all the options out there; any good suggestions?
Thanks
w.
Iiyama ProLite E2409HDS on offer at OCuk @ £144 - Stock Code: MO-067-IY.
My mate has just got one, must say I impress with it, a nice 24".
