- 9 Jun 2011
Hi guys, what do you all use to reseal the 8700k? once you've delided? I'm trying to make it asclose to stock as possible
maybe warranty worth if it goes
where did you buy it from dudeI used Black RTV silicone gasket maker.
Hi Face
Just buy any (the cheapest) high temp RTV from the rain forest. You will only need a very small amount.
Also, get some clear nail varnish (I used clear coat paint) as there are 4 small contacts you will want to cover - assuming you are going liquid metal.
Def use liquid metal. Thermal Grizzly conductnonaut
I was going to use Noctua non conductive thermal paste, not sure if this is any good? should i go Liquid metal? Tempted, thanks for highlighting this
Glad you've gone that way. Buy a small tube as just like the RTV, a small bit goes a long way.okay liquid metal it is, now for the nail polish xD
Just a word to the wise, practice the application before you do the real thing. More squirts out than you would think.
thanks,
is there a big difference between thermal grizzly and liquid metal
Bloody hell! That's not coming off then is it.I used JB weld on a G3258, both on the small surface components and to seal the IHS back in place. Maybe slightly OTT but it definitely works![]()
I used JB weld on a G3258...Maybe slightly OTT but it definitely works![]()
MAYBE SLIGHTLY OTT? Dude, that's bloomin' mental. I love it.
I'd love to see a direct comparison now between Conductonaut and JB Weld under the IHS![]()
