Hey,
I have a H80 with stock fans hooked up, cleared up my airflow in my case, all that jazz. Overclocked to 4 ghz, and when testing first time round, got max temps of 75c with the fans plugged into the motherboard. Ambient temps about 25c-ish. After testing it was stable, plugged the fans into pump, tested again, got temps of 80c. Plugged back into motherboard, stuck at 80c. :S
Then I remembered when I was setting it up, I accidentaly used the LGA 2011 screws, realised my mistake *after* plonking the pump onto the cpu. Didn't have any paste, so I did best as I could, replaced the screws after taking of the pump (smeared the paste in the process a bit). And whacked the pump on with the correct screws.
So, uh:
1) Does anyone have any idea why my temps jumped at similar ambient temps?
2) Should I reseat?
3) Which paste should I use? I was thinking about pk-1.
4) Any fans that aren't so..loud?
So, uh:
2) Should I reseat?
