Reseating heatsink
10 Oct 2006
When the heatsink is reseated on a E6600 with reference cooler should i replace the thermal compound as shortly after building i had to reseat the cooler and i didn`t replace the compound? Just wondered if that might be why my temps are slightly high
You should always replace the thermal paste when you remove/reseat/change the heatsink as the connection is broken between the CPU and the heatsink
