- 29 Oct 2005
- Newcastle upon Toon
Anyone know if / how a Zalman Reserator can be used with a Core 2 Duo processor (socket 775).
Cheers,
M
Cheers,
M
WJA96 said:This is a Reserator 1+ block on a Gigabyte P965 DS4 - it barely holds an overclocked E6600 (3.6GHz) to 65C (full TAT load) on a warm day.
As far as I know Zalman use one mounting system for all their cooling devices, so if you have any Zalman S775 cooler, this will fit the bracket.
noxidjkram@hotm said:I may be running a standard clock e6300
. WJA96 said:Strike down the sinner! You can't not clock an E6300 - it's a waste. You might as well buy a fast AMD chip as it'll be as quick.
They're not that fast at stock, but clocked up they do shine.
