I doubt it will do at all.Wayn0r said:im not particularly that bothered about overclocking, more quietness. all im bothered about is wether the reserator 2 will not get too hot cooling a core2 and an 8800? its either that or mess about with a full watercooling setup which i really cba with![]()
m4rtin said:wont you need 2 blocks?, the ramdac is under the cooler on the gtx so that might need something. tbh that £100 more on the proper watercooled one is worth it as you know its gonna be good
Well it is not the reserator & is nothing like the reserator 2.PinkFloyd said:I doubt it will do at all.
Thats a lot of heat to take with a passive setup.
StevenG set up a Thermaltake tower thingy (basicaly the reserator design) on his core2duo and it idled at 61 degrees.
Add a 8800gtx in there too and its not going to cope.
