Just the man i was thinking of
I wondered if a DDC would be to powerful seeing as the Reserator is not very restrictive and i wondered if you could hear the water traveling through the loop but as somebody thats into quiet systems i was just thinking about emailing you but you saved the trouble
DDC are sometimes known to make a rotor whine when they are not under heavy load can you hear any from your DDC at all. ?
Did you leave the flow indicator inline in the DDC loop and ifso does it rattle ?
And did you have much trouble getting the base off and did you use a sash clamp or one of those strap clamps for removing oil filters ?
But with 3 blocks and the CPU block being up high in my full tower i think it would be too much for the 5w pump
