Reserving drive letter in win 8.1 for usb dvd writer
17 Dec 2004
I am trying to stop other usb devices using letter E accept for the dvd writer, but its not working, can someone help me out?
Im using "USBDLM" to try todo this, but everything I try my usb sticks keeps using E drive? This was my last attempt at editing the usbdlm.ini file.......
The way I'd do it is:
Control Panel -> Admin Tools -> Computer Management > Storage -> Disk Management.
Right click on the drives/disks and select Change Drive Letter and Path and go from there.
There's probably a short cut to get the the above.
If you're using Win 10, right click on the Start button and select Disk Management, for example.
Using disk management, you should reserve a letter high towards the end of the alphabet that would never get used by default. Then windows will remember it every time you connect the device.
