I need to get a Reservoir for my loop, do I go for pump mounted EG: http://www.overclockers.co.uk/showproduct.php?prodid=WC-311-EK&groupid=962&catid=2133&subcat=2136
or stand alone (Can't use bay's they are full) , I'm guessing it's more personally preference but want to use as little fittings as possible so I assume pump mounted would be better in this instance?
Thanks
and how much fluid should I order for a CPU only loop with 240mm rad ? would 1Ltr cover it or should I double up
Thanks
