- 18 Sep 2011
I need some help deciding what parts I should get and how the peformance will be compared to other products. If I do decide to overclock it will only be minimal on my I5 so high performance isn't needed that much aslong as it's cool. I have a Swiftech MCP655 pump.
CPU Blocks -
I've been looking at the Raystorm but I can purchase a new Delta v3 for £20 instead of the £50 for the Raystorm, how do they compare and would the extra £30 be worthwhile?
Reservoir -
Acrylic Tank Reservoir for Laing D5
or
Acrylic Dual 5.25” Reservoir for Laing D5
If you have any other suggestions please say, my budget is up to £150 but lower the better as money will be used to update my aging 250gts 512mb. Note this is only for a CPU loop.
CPU Blocks -
Reservoir -
or
