currently planning the layout of my watercooling setup, and before i finish the case mods and start installing stuff i have a question that i haven't been able to find a goods answer from with google yet.
basically my current plan had my reservoir in about the middle of the case, and i am wondering what happens when i come to fill the system. it's a cylinder res, one of these aquatube
it will be below the height of the cpu.
other details, its a single loop system, in a tj07 with pump and rad in the bottom, 2 graphics cards watercooled and cpu watercooled. the res is placed on the mid deck and i can't put it anywhere else due to other mods.
i was going to add a fill tube from a t piece in the tube going from the cpu block to the res, then use that to help bleed air out. i was thinking what would happen if i removed the top from the reservoir to fill it. will the fluid overflow from it?
