Noob w/c question, I read that the reservoir needs to be before the pump in the loop and that the rest of the component order does not matter too much (ie rads, blocks). Question is does the reservoir (a tube reservoir) need to be before the inlet of the pump, in this case a D5, or can it be ahead of the outlet? Reason I ask is that I would like to position the reservoir physically directly above the D5, and this is above the pumps outlet (which is vertical) and not inlet which is horizontal. If the reservoir can be positioned at the outlet it would make for easier routing.
Thanks
Thanks
