reservoir/pump combo advice
I have it and I have it in a HAF-X. It's not a bad combo at all, the pump can be a bit audible on the highest setting and people have had multiple problems with it vibrating againt the chasis but when I have all my fans running at 800-1000rpm the pump is the only thing I can hear and I have to strain to hear it (And that's on setting 3)
I should add that I'm getting rid of it soon though and going for a tube res, mostly for aesthetics.
you get anti vibration pads for a couple of pounds but yeah the d5 rules from all the threads i have read and if like most you use a gaming headset or descent speakers you will barley notice if not at all :)
