reservoir question
28 Jan 2015
I m thinking of going for an Evolve X when they are out and currently have a dual bay reservoir and D5 pump.
I need to keep pump as it is an Aquaero D5 USB pump used in Aquasuite 2018 software but would be needing a reservoir as the dual bay wont fit.
Any ideas of reservoirs that could be used with the D5 and more importantly, where it would be located!!]
Thanks
You could get one of the reservoirs that acts as a D5 top - there's a multitude of choices, all quite similar. Acrylic tube with a block at bottom that holds the D5 unit.
Check out XSPC photon reservoirs, they should work with your D5 and quality is much better then the plastic EK crap, also monsoon MMRS is great, and you can build it just how you need it.
