Hey guys im currently considoring changing my current loop which is currently just cooling my CPU through a 360 black ice radiator using only 3 fans pushing upwards and outwards of the case (Corsair 800D).
I suppose I have two questions here.
Firstly what do you think of adding 2 graphics cards to that same loop (would the temperatures be terrible or will they manage just fine)?
Also I want to add a bay reservoir, preferably a dual bay (but single loop) but im not sure what I should be looking for exactly. Im hoping to get something that I can fill/drain fairly easily.
Also im thinking that getting a separate pump rather than a pump combo will be better as if one breaks (most likely the pump) I will only need to replace the pump and not the res... Does that make sense, or is it better to just get a duo?
Thanks in advance!
Thanks in advance!
