I'm trying to piece together the last piece of my watercooling puzzle that has really been getting to me, to the point that I can't sleep.
The D5 seems to be a superior pump to the DDC so I'll probably go for one of the topless alphacool D5 vario ones. Mounting any pump is a pain, so I've pretty much decided get one of three options:
a)Danger Den Monsoon D5 Premium
b)EK-D5 X-RES TOP 140 with a longer tube mounted to the rear of the HAF
c)XSPC dual bay for D5
The XSPC has me worried with the build quality, and it might be tricky to bleed compared to the DD.
Primarily I want to be able to keep this build pretty quiet so will be replacing my fan controller with a Lamptron as I'm not hugely impressed with the NZXT one and running the pump from it.
Is there anything obvious I've missed with opting for a pump/reservoir combo, most people seem to use the tube reservoirs and separate pumps. Is it a noise thing or just convenience?
