Reset after throttling 280x
17 May 2013
West Sussex, UK
Having a few problems with GTA5 crashing.
Thought I'd double check my temps, so ran Furmark. GPU managed to reach 99 and it throttled the core to 501Mhz. The card started to cool down. It's been 10 minutes now, and it's cooled down, but I can't get the GPU to run at max power again. Surely it should start working fine again once temps have dropped?
Gigabyte Windforce OC Rev.2
Not sure if you're still having issues, but you probably just need to reboot your PC. Whenever I've overclocked a GPU, if it's started producing artifacts (i.e. my OC has gone too far) I normally have to reboot the PC even if I've lowered the overclock.
