4 Feb 2009 at 14:06 #1 jalin jalin Associate Joined 4 Feb 2009 Posts 2 How can I reset the BIOS for a Laptop Toshiba A215 ?
4 Feb 2009 at 14:46 #2 beermonster beermonster Soldato Joined 19 Oct 2002 Posts 3,164 Its usually F9 when your in the bios. F2 to enter it on start up.
4 Feb 2009 at 16:19 #3 jalin jalin Associate OP Joined 4 Feb 2009 Posts 2 What I mean is the same that somebody ask on Feb 1, but he asked for the model A210. Is the same for model A215?
4 Feb 2009 at 18:19 #4 beermonster beermonster Soldato Joined 19 Oct 2002 Posts 3,164 Not sure, but if you have the same jumper under the memory slot then yes that method will work.
