- 12 Feb 2006
- Surrey
i downloaded some text files a month or so ago but one of them have caused a problem now whenever i use the text tool so im wondering if anyone knows a way without uninstalling and installing as i really can't be bothred if there is any easier solution to it.
the problem with it is that when i select the text tool and then click on the space to tpye, the blinking cursor thing is huge, like 10 times bigger then the size i choose, so if its size 8, the blinking thing will be size 80, size 100, the thing will be like 1000.
thanks
thanks
