I bought this game and have installed/patched it up as normal = no problems.
So when I came to play the game I noticed I had a major problem, the controls! It looks like you need to use the numeric control pad ....
789
456
123
Something like the above which my keyboard does not have (A few modern keyboards don't have this as its not REALLY used that often). So my problem I'm having is that I cant change the control because this is clearly a cheap port from console as when I looked at changing the control it just gives you 2 options which were on the console port for the controller, it even mentions the joystick control system on there!!!
Does anyone know a way around this or do I need to buy a controller to play this game? And if so what controller should I get?
Again
Ta
789
456
123
Again
Ta
