Get over to ign fellas, they are handing out 7000 beta keys for resistance 2 ... first come first served.
I already got mine![]()
No EU codes.Known them its probably for the US only.
So how do you actually get the key?
No EU codes.
http://uk.ps3.ign.com/articles/921/921963p1.html
IGNore needles and go here:
http://www.fileplanet.com/promotions/resistance2/index_reg.aspx
rp2000
rp2000, you cheeky so and so..... sorry for lack of link guys, posting from the ps3.
Just wanted to give you guys a heads up, its the only way left to get into the pal open beta.
So I was franticly looking for a link or something to sign up to!
2.2GB. What is it? The game itself or just the multiplayer portion?
Thanks, rp. (And Needles for bringing it to my attention!) The online campaign is not the same as the single-player story is it?
But you go to IGN and there's no info apart from being told to install Comrade, which I can't do at workSo I was franticly looking for a link or something to sign up to!
It's not the only way as pre-ordering the game gets you a beta key.
