Resizable BAR help
26 Aug 2010
hey
so, ive only just found out about this , so i decided to give it a go as im about to play cyberpunk
anyway, ive downloaded MSI Dragon center to flash my card to the latest bios and it says theres no updates.
gpu-z says my bios is (94.02.85.00.9D) and the interweb say im on the latest gpu bios for my card.
ive checked my mobo bios and every is sorted there too.
Nvidia control panel says it isnt enabled
specs are
gigabyte aorus elite z690
msi 3080 gaming z trio 12gb
am i missing something?
thanks
Done all this?
  1. Boot in UEFI mode and enter BIOS.
  2. Go to Settings and enable “Above 4G Decoding” and “Re-Size BAR Support”.
  3. Go to Boot and disable “CSM Support”.
  4. Ensure GPT partition type is used (and not MBR).
  5. Save and exit BIOS, then reboot your PC.
Done all this?
ive not done that no. but when i went into bios 2 and 3 was already sorted. dont know what the others are but ill go and google that
thanks
hey
specs are
thanks
Should be similar to this:
Thanks chaps. I just needed to boot in UEFI mode and enter BIOS.
I did that and restarted the pc and it was on. Everything else was already set up. I think its because the mobo is z690 it was ready for it.
Thanks again. Ill vet on cyberpunk tonight
