Resize image to fit resolution
Permabanned
30 Dec 2005
16,000ft
Hi,
Really sorry to start a new thread for this - but I can't find it on a tutorial.
Basically, I want a website background image to always fit the screen, no matter what the resolution. How can I do this?
I am sure there must be the relevant code somewhere, and it's probably really simple.
Thanks for any help.
Create the image using max resolution (like 1280x1024 or something), then when you want it as your background, under Display Properties | Desktop, choose the Position of "Stretch".
Nooooo, I'm talking about a website background image here.
So when someone with 800x600 resolution visits it doesn't extend off the side of the page, and when someone with a huge monitor and a 1600x1200 resolution visits, it doesn't have a border around the edge.
Basically, I need a script or something which resizes the background image dependant on the visitors resolution.
