Resolution change shortcut.
5 Jul 2003
Atlanta, USA
Hi.
Does anyone know of a default shortcut in windows for changing resolutions?
Some of the kids keep doing it here, but for the life of me, i cant work out how they've done it.
Ideas?
the intel graphics driver program has "hotkeys" dont know what they are though, also some of them have the option to change res from rclicking on the tray icon. have you bared the destop properties process from running? or at least task manager/command prompt? The only shortcut keys i can remember atm are the ones for rotating your desktop, which dont seem to work on my work PC atm....
Without you describing what you have set up to limit access and what you are limiting it to its slightly hard to help you.
We dont have any fancy software to disable programs/services like that unfortunatelly.
Its odd, because it is disabled in the options (the hotkeys in the intel drivers), yet it still allows resolution changing?
