Resolution issue with dell 2407wfp
8 Feb 2007
Just got my new monitor today, and the drivers disk wont work with vista 64, so i downloaded the drivers from dell website but they dont install, you just extract them somewhere and supposedly a web browser comes up and helps you install, well that doesnt happen, so i cant up the resolution from 1600x1200 anyone got a solution!?
Go in to device manager, find your monitor and right click on it and select update driver, then select the folder where the driver you downloaded unzipped to and it should find the appropriate file. You shouldn't need the driver to set the resolution anyway.
yeah the problem was i have my lcd tv on the same card, at 1368x768 reso and i deleted that and then it let me set it to max, but now i cant get my tv reso back, not even after deleting the dell, so i might have to whack in a crappy x800 as a second card to run the tv off, would that work though?
any other suggestions welcome
