Resolution on 4k monitor - scaling
31 Dec 2003
Stoke on Trent
Hi, are there any tips on how to get the menu bar etc not tiny but using a 4k monitor please?
My resolutions settings didn’t have the word “scaled” to choose from
You should have an option that looks ok, have you tried them all and can’t find one to settle on? In which case you might need BetterDisplay
I settled in 1440p but it feels a waste of the resolution like I should have got a 1440p monitor.
The windows of most apps I can get acceptable (but still not great, e.g gmail has weird big wriiting) but the Mac top bar itself has text and icons so tiny it’s ridiculous
Sorry for any wrong terminology I am fairly new to macOS
Go into system report if it’s says resolution is 5120x2880 but UI looks like 2560x1440 then it’s running in Retina mode and is decent on a 4K monitor.
Here’s mine…
Here’s mine…
It says apple m1
PHL 329p1:
5120x2880
Ui looks like 2560x1440 @ 60Hz
Congratulations you’re running a good resolution on your 4K monitor, don’t feel bad about it being 2560x1440 it’s in Retina mode which makes up for it.
I think I understand lol. I’m used to it now and am enjoying it just can’t help think I’m missing out and “wasting” resolution…..
I have my Windows 11 machine set to 3840x2160 but it's scaled to 150% which means it's actually running at 2560x1440. A Mac running at 2560x1440 in Retina mode will look sharper.
I have my windows machine running at 4k 150% UI, I am going to connect my mac later and try this to see if it looks the same or sharper. am sure the text will still look better on a windows machine as its not a true 200% retina because for that you would need to set the resolution at 1920x1080
You was correct I connected my Mac to a 4k 32 inch screen and scaled at 2560x1440 and it looked quite decent, very close to what my windows laptop looks like at 4k 150%. from what I remember it didn't look this good on Sonoma unless its just my eyes
4K scaled to look like 1440p on a 27” monitor looks good. Text is crisp and clear and the UI renders well. 5K would be better of course but there’s a balance. Choosing 4K means I can use a high refresh rate monitor, so I run 144hz 4k 27” on macOS (I have 2 macs actually connected to this monitors KVM).
I am also new to OSX and the whole scaling thing is a pain.
I installed BetterDisplay in the end but there are so many things that OSX does that need third party apps to fix that it's crazy to think that Apple are just happy to go with the current OS behaviour instead of giving people the option.
I don't like that OSX opens a new folder when I open a folder. If you have 3 tiers+ of folders, it gets annoying and choosing the tab option is OK I guess but what if I don't want 3+ tabs either?
There are so many other behaviours that are weird too.
Windows isn't perfect but it's at least consistent in it's approach to things system wide e.g., setting folder behaviour for all folders in Windows is easy, not so much in OSX and you have settings for the same thing in different parts of the settings menu too.
If I'd spent £2000+ on a MBP or something, I'd be ******.
Agree on needing so many third party apps, it’s frustrating. Apple are so dogmatic with their way of doing things.
That said, I still prefer macOS, even with the extra apps, than windows.
Honestly I can use just about anything but I do miss the customisation options in Linux.
Yeah I’m getting used to OSX and make no mistake, Windows isn’t perfect (in OS adverts? A system search that can’t find anything? Assumptions that Windows works properly across millions of hardware configs which leads to a ton of instability?).
