resolution problem 1920x1080 HDTV
2 Dec 2007
Leeds
Hi,
I am using my Samsung 40" HDTV as a PC monitor through a dvi to hdmi cable and am unfortunately having a problem with it. Whenever i select its native resolution of 1920x1080 the picture will be too big for the screen? so normally I have to scale it down in NVIDIA control panel to the custom resolution of 1804x1004. However I recently bought Starcraft 2 which does not have custom resolutions supported so i am forced to run i in 1920x1080 with the next best being 1680x1050 which I really don't want to use. Can anybody tell me how I can get the HDTV to run 1920x1080 but still have the picture perfectly fit the screen???? Thanks in advance.
I enabled something called Just Scan on my HDTV...is this overscan? it was 16:9 before but that didn't fit the screen? What does just scan do exactly? it doesn't stretch the image does it?
I jsut read a description that says "Just scan means the picture has no overscan or underscan, so what you're seeing is "edge to edge" picture without processing upscaling or downscaling." Can anyone enlighten me to what this does as im still clueless? lol thanks.
