Resolution problem
Permabanned
8 Mar 2005
I've been using a monitor at 1440x900 for the last few days, but today I switched back to my 17" TFT @ 1280x1024. Now being the silly person I am, I have left GTA:SA in 1440x900. It will not display now ive switched back monitors. If I remember correctly, there is a way of setting the window height and width on the end of a program shortcut? Does anyoen know how this is done?
I'll take ti you still dont have access to the larger moniter?
Right click the shortcut, go to properties, click compatibility nad select run in 640 x 480 screen resolution. Run the game and change your settings back and then unselect this afterwards
any monitor should be able to display 640x480 it's one of the most basic universal resolutions (everything from the bios to dos, to windows setup uses it).
Go to the "My Documents\GTA San Andreas User Files" folder and rename or remove the file: gta_sa.set
That will reset the default game settings and resolution.
